grombulator
I have the sensitivity set to 2 out of 5 for all three directions, and it still seems way too sensitive. My event folder is full of locked files from me going over the smallest of bumps. Is this normal?
You need to contact support. Perhaps in the next update they will change the sensitivity. The N4 Pro G-sensor is also very sensitive. I turned it off.Yeah, I don't actually see much need for the g-sensor. I just think it could be a sign of other issues as well, that might come up with time, like if it was dropped before I received it. And I want it to last for many years.
I just set all the axes to the lowest setting, I'll see if there are false events.
I am familiar with Viofo products. On different models and even on different firmware, the sensitivity of the G-sensor is different.I used to have a Viofo, and on medium sensitivity, it would only lock videos if I went over pretty intense potholes or similar. With this camera at 2/5 sensitivity, it's locking videos on small, normal bumps in the road that you can barely feel when you go over them.
Get a big memory card and turn off the G-sensors.Even after setting the lowest sensitivity in all three directions to one, in one day I had five event recordings. Two of them were when my car was literally not moving in a parking lot.
You don't think this is worth returning and replacing? It could be a sign of other issues that could spring up later, I think.Get a big memory card and turn off the G-sensors.
In my experience (but none with Vantrue) both G-sensors and motion detection in dash cams are marginally reliable at best. If it records when it should and video quality is decent I wouldn't bother with returning it since it's likely the replacement would be the same.You don't think this is worth returning and replacing? It could be a sign of other issues that could spring up later, I think.
