R18
Hi,
Sorry for such a nooby question. I have scoured the internet and can't find an answer to this, and I dont have the means to test fuses.
I am trying to hard wire my A129 Duo into my 2017 Ford Focus ST line (https://www.startmycar.com/gb/ford/focus/info/fusebox/2017). This has permanent and switched power cables which I would like to use fuse taps into the passenger fuse box.
I already have a fuse tap installed from an amplifier which occupies fuse #86 and blocks access to the two fuses above, and the fuse to the left (https://ibb.co/4SVSTWs). Due to how the taps work I also won't be able to use the fuses in the left hand column (I think).
Am I able to tap into the existing fuse for switched power?
Is anyone able to please tell me which fuses are the best to tap for one constant power and two switched fuses without conflict?
Thanks!
Thanks!
