A119 Mini 2 Lens Check
geokilla
Didn't want to clutter @rcg530's thread so I decided to make a new thread for it.
How Can You Tell - If Your A119 Mini 2 Has The Updated Lens
I get this question frequently and so far I've not been able to identify a way to see if the A119 Mini 2 has the original lens or the updated lens. I no longer have the two A119 Mini 2 dash cameras with the original lens. VIOFO requested I send those two units back to them for their investigation on the heat defocusing issue. I took a good look at the two A119 Mini 2 dash cameras that now I have installed in my car. I looked very closely at the front lens area and I did in fact find a "difference". I compared the updated lens with the original lens (in my unboxing pics) and there is a noticeable difference. The ring/bezel around the lens glass appears to have a different shape between the original lens and the updated lens. The exposure level of level of my unboxing pic was a bit dark, so I asked @Panzer Platform to take a picture of his A119 Mini 2 with the original lens. His picture and my picture show the same shape to the ring/bezel around the lens glass.
My unboxing picture of the A119 Mini 2 with the original lens:
Panzer Platform's picture of his A119 Mini 2 with the original lens:
If you look closely at either of those two pictures of the original lens, you'll see a flat spot at the outer edge of the ring/bezel and then there is a very slight taper running down towards the lens glass. If you look at my picture of the A119 Mini 2 with the updated lens, you'll see a very thin outer ring and then the remaining portion of the ring/bezel has a far more angled taper as it goes towards the lens glass.
My unofficial way to see of your A119 Mini 2 has the updated lens is:
  • If you purchased/received your A119 Mini 2 before July 2023, then it will not have the updated lens.
    • VIOFO has stated the production change to the A119 Mini 2 lens took place in July 2023.
  • Using the pictures to compare to your A119 Mini 2
    • Unless there was some other reason for VIOFO to vary the ring/bezel around the lens glass:
      • If your A119 Mini 2's lens has the ring/bezel I show in my picture of the unit with the updated lens, your A119 Mini 2 has the updated lens
      • If your A119 Mini 2's lens has the ring/bezel I show in my picture of the original lens, your A119 Mini 2 does not have the updated lens
  • You could also contact VIOFO and submit a support ticket asking them if your A119 Mini 2 has the updated lens.
If you want to know what the ring/bezel around the lens glass of the previous generation A119 Mini (not the Mini 2) looks like, here's a picture of that one. Its ring/bezel is completely flat.
I think I have the new lens as well? I bought both cameras on AliExpress in August.
Can anyone please help me and tell me whether my mini2 already has the new lens
Yes, you appear to have the new lens.
