A129 Duo & IR, are the Rear Cam interchangeable?
AlexTan
Kuala Lumpur
Malaysia
Viofo A129Pro Duo A129 IR Duo A119 A119S A118C & Dome GS98C
Hi.
The A129 Duo & A129 Duo IR, are these Rear Cams interchangeable? Does it work with different Firmware?
Anyone try before?
If use the infrared interior camera as rear cam, the video color will have some pink, or you can accept white / black style video.
What if I have an A129 Duo IR, and I bought a regular A129 Duo Rear cam only, and use it on A129 Duo IR as the rear cam, does it work?
Firmware is changeable.
Meaning, it is possible to install the regular A129 Duo firmware into my A129 Duo IR without any problems or negative effects?
just install the normal A129 firmware
So, both firmware IR and non IR firmware are interchangeable on both models?
Yes, but if your using the IR rear camera, then you want to have the A129 DUO IR firmware installed on the main A129 camera. If your using the non IR rear camera, then install the regular A129 DUO firmware on the main camera.
Thanks everyone for the information.
Top Bottom
