Hi guys, recently I purchased ddpai mini2. Tried to update firmware but it stopped responding. Please help how to do factory reset. Also my app can't connect to my cam. Any one can help?
my cam stopped responding, only red light indicator is on. Reset also not working. Is there a way to download the latest firmware using TFcard? TIAFirmware upgraded by OTA must works;
It is much much convenient than manual upgrading;
If OTA upgrading can't be complete, turn off DDPai APP(stop it from running at the background) and turn on DDPai APP again and then try again.
Hello friend,my cam stopped responding, only red light indicator is on. Reset also not working. Is there a way to download the latest firmware using TFcard? TIA
cannot find DDPai camera on phone wifi listHello friend,
1, if camera LED "orange flash", it means camera itself works normally.
2, then: Your phone---Setting---Wi-Fi network: can you find DDPai camera in your phone wifi list?
3, Yes, I can send firmware to you for manually upgrading.
The same problems. Looks like DDpai is the worst cameras in the world. WiFi doesn't work. Upgrade doesn't works. Support doesn't respond. I will tell to all of my friends and everywhere in the internet to - DO NOT BUY THIS **** !!!!I've had issues with the DDpai app not finding my camera too, especially after ive took the SD card and put back in, the app will randomly say it cant find the camera. The wifi will sometimes take forever to connect, or make me re-enter the password a bunch of times, and then it will randomly work with no problem... Once I had to completely reinstall the app before it would connect. A lot of other apps dont work while connected to the camera wifi tho. Anyone else have that problem? (Galaxy S7)
Dear Friend,Hello friend,
Hello friend, pls PM your mail address and then I can upload the upgrading file to you directly.Dear Friend,
Pls help to send the firmware of DDAPI mini2 for manual upgrading. Thank you
Joel
I have been having a similar problem for months and finally solved it so I wanted to share. Basically, I think an OTA update went wrong and the unit wouldn't take my password or the factory default. Pressing the factory reset button did a reset but didn't affect the password issue so the app could never log into the camera.
Solution: do a manual file update (get the firmware from the .cn site, unzip, and put into the root directory of the SD card that goes into your camera). After this you can use 1234567890 as the password and you are back in. NOTE: the US site has a problem not taking you to the actual download center, so you need to go to the .cn site to get the firmware.
Hello friend, PM to me and then I will upload the firmware to you for manually upgrading.What is the .cn website?
Hello, Fabio!Hello friend, PM to me and then I will upload the firmware to you for manually upgrading.
Hello friend, you could PM your email address and then I will upload the firmware to you via www.wetransfer.com thanks.Hello, Fabio!
May you give me the link with the firmware Ddpai mini 2?
Regards,
VH
hi can you send me firmware of mini2 link to : khanh8707v@gmail.comHello friend, you could PM your email address and then I will upload the firmware to you via www.wetransfer.com thanks.
G | DDPai mini2 hardwire kit | mini2 | 7 | |
DDPai Mini2 [Black Edition] | mini2 | 13 | ||
How does ddpai mini2 always have correct date/time stamp? | mini2 | 7 | ||
J | What is performance difference between DDPAI mini & mini2? I see none | mini2 | 5 | |
DDPai Mini2 Review | mini2 | 97 |
