Have a hardwired A129 Duo, with front and rear fitted.
I noticed again, that I had the left hand and middle flashing LEDs, so wasn’t recording I presume. What is this error?
I use a 256Gb Samsung SD U3.
I removed the SD and had a look on the files and there was a couple in the middle that wouldn’t play and seemed corrupt.
Put the SD back in and same, I had to remove both cables for a while to the unit, and then got solid lights again.
Is this just how it is? I should power cycle every month or so?
I use constant parking record mode.
I’m all up to date on firmware, and I format my SD every few months.
