Manx Viking
- Jul 5, 2016
- United Kingdom
Dear All
dashcam - LK-7950 without OBDII (currently firmware 21)
Lukas Viewer 2.0.2.0
App version 1.5.3
128gb sd and 128gb microSD card
I recently purchased an LK-7950 off ebay from Korea, no issues with that except it had firmware 19 on board and locked in Korean language. reading some of the posts on here from the very helpful members on this forum resolved that matter, but at the same time i loaded firmware 21, again with English audio.
i noticed the parking mode was incredibly sensitive, even on sensitivity 1 and picking just the lower band to observe (closest to the car) but birds and bushes further away meant that i had almost continuous recordings, not ideal if i wanted to find something. also on firmware 21 the rear LED doesn't operate (whether i enable in app or viewer). anyone any ideas why (but see below about firmware 17)?
i downgraded to firmware 17 (from this forum) to see if that resolved the sensitivity for parking, it seemed to, but i noticed the front recording and rear weren't synced in viewer (and the quality of the rear camera seemed degraded), however using firmware 17 did make the rear LED work so its not a hardware problem.
can i ask, does anyone have a version of firmware 19 i could try (i never gave it a test before upgrading to 21 following audio problem with 19)? and some advice on the sensitivity of the parking mode? or making the rear LED operate in firmware 21? thanks.
i do realise that unless the car battery is an issue continual recording in parking mode might not be an issue, except if i needed a file i'd have hundreds to go through and the constant writing to the SD card is only going to shorten its lifespan so i'd rather avoid. hopefully this will get sorted in a later firmware but i'd like to try v19 if possible.
many thanks on advance for any advice and assistance
kind regards
MV
App version 1.5.3
kind regards
MV
