- May 1, 2013
- Dublin
- Ireland
NB!
ANY DIY MAY VOID WARRANTY OF THE PRODUCT !
ACT ON YOUR OWN RISK !!!
DIY ball-joint low profile mount for Panorama G / Street-Guardian SCZC12G )
Why in some cases we need a ball-joint mount ?
Most other Panorama G low profile compatible mounts have only 2-axis adjustments, but in many situations we need 3-axis ( X, Y, Z ) adjustment in order to have a correct camera lens / footage angle.
Unfortunately there are no out there low profile ball-joint mounts that would fit Panorama G or other dahscams with similar bracket mount ( mostly DOD LS300W-type )
So I have decided to make one.
I got one low profile ball joint mount which looked on picture to be just the right thing for the job ( before receiving it ), but after I have receiving it, I discovered that it does not fit 100%, so I had to do some DIY.
First I have file down edges of mount about 1mm from different places, in order to fit into Panorama G GPS module.
Next step was to straighten original ball joint "arm". I have used hot-air soldering ( 200C air flow ) to soften plastic and straighten an "arm".
Then I had to heat up plastic again and bend an "arm" slightly forward
Final result.
Final result.
