MechanicalMan64
- Feb 28, 2015
- Canada
Fuse Tap Dash Cam Problem
Hi All,
I'm just using my previous post instead of creating a new one.
So recently I've ordered 2 standard mini ATC fuse taps and fuses along with the female cigarette lighter sockets (see diagram below) with the intention that I install one for my Camry and one for my 2014 Lexus ES350.
I've successfully installed the Camry with no problem. However, when I moved on to the Lexus I realized I needed the Low-Pro Mini ATC Fuse tap and fuses... so I ordered those and it came yesterday.
I'm piggybacking off the 15A cigarette fuse and tried many ways and there's no way I can get power in my newly added socket. But when I plugged it back into the cigarette socket it works?
Here's what I tried:
1) The original 15A cig fuse + 5A cig fuse (made sure the placement is correct- that is the 15A first then 5A second)... doesn't work
2) Used both 15A original cig fuse + 15A fuse from ebay... doesn't work
3) Borrowed the rear cig socket 15A fuse and used both factory fuses... doesn't work
4) Triple checked the female cig socket connections to the fuse wires... doesn't work
5) Used another fuse spot tap instead (ie. the rear cig lighter)... doesn't work
In all these instances above, I was able to get power in the original cig lighter socket but just couldn't get anything on my newly fuse tap?
Any idea?
For reference, this is the one I picked up: https://www.ebay.com/itm/291463069422
ORIGINAL POST
Hi All,
Just wanted to run this idea through you guys for any comments or feedbacks. Essentially, I have two dash cams (one in the front and one in the back) that I would like to hardware via fusetap.
Just wanted someone to help me confirm if:
1) 3A fuse is sufficient for 2 dash cams? Do I need at least 5A?
2) Can I connect both the red wires into 1 single fuse tap? Or do I need two separate fuse taps?
Attached diagram for reference of what I essentially want to do here:
Hi All,
Any idea?
ORIGINAL POST
Hi All,
