GS36H File management
ttk
Dortmund
Germany
I have a GS36H camera and some problems grasping the concept of file management when locking a file:
It seems that whenever i lock a file with the middle button, all files which are currently on the SD card are marked as locked in the app when i connect to the camera's wifi. Is that correct or are there some misconfigurations from my side regarding movement or acceleration sensor? If yes, what would be the correct procedure to clean up the lock after downloading the needed video clips from the camera? Completely formatting the SD card? However, if the SD card is almost completely full, would i need to park and do that right away because the camera would not be able to record new data since the card is full and all files are locked?
How would i configure the movement sensor? I have noticed when it is enabled and i am driving, the camera is locking every file as well, because obviously there is movement when i am driving. What are your recommended settings here?
