How / Where To Order More Sticky Pads?
DashCamOnBoard
I've got an SG9663DCPRO and will be removing it from 1 vehicle and installing it in another. After peeling both cameras and GPS puck off with the string, I'll need new double-sided stick pads. Is there a way to order new ones somehow? Or is there something we can just get at a hardware store?
Thanks.
The adhesive pads that come with dash cams are most often made of 3M VHB (Very HIgh Bond) tape # 5952 (and similar). This same tape is available in rolls and pads on Amazon and at places like Home Depot or your local hardware store.
You can also use Scotch-Mount Extreme Double-Sided Mounting Tape (also made by 3M which is a version of the same thing.
With tape in roll form you simply put two or more pieces together side by side and trim off the excess. Same with pads that may be bigger than your camera mount.
https://www.amazon.com/s?k=3M+VHB+tape&link_code=qs&sourceid=Mozilla-search&tag=moz-us-20
https://www.amazon.com/s?k=scotch+mount+extreme+outdoor+double+sided+tape&crid=3PN4AQFCMBEEL&sprefix=Scotch+Extreme+outdoor+tape,aps,305&ref=nb_sb_ss_ts-doa-p_2_27
https://www.amazon.com/gp/B018GKCI82
