rcg530
- Jan 23, 2021
- California
- United States
- BlackVue, Thinkware, VIOFO, Vantrue, Blueskysea, FineVu
I'm testing a Thinkware OBD-II power cable and it appears to use the CANBUS signals on OBD-II data link connector pins 6 & 14. It was suggested I get the IROAD OBD-II Power Cable (JW-100) to see how it behaves. @BlackboxMyCar was kind enough to send me one of the IROAD OBD-II power cables (JW-100) for testing.
Pictures:
The IROAD OBD-II power cable only has two data link connector pins. Pin 16 for 12-volt vehicle system power and pin 4 for the ground. The barrel connector that plugs into the dash camera has the ground on the large external connector, accessory power on the external tip ring and constant battery power is present on the internal connector. The cable which supplies power to the dash camera is 2.95M (9.67 ft) in length and it contains 22 AWG wires. This unit is a JW-100 which is compatible only with 12-volt vehicles (ICE/Hybrid). There is a JW-200 unit which is intended for electric vehicles.
Specifications (from Quick Start Guide):
Model: IROAD OBD-II Powercable
Model Number: JW-100 / JW-200
Input: DC 12V ~ 15V
Output: DC 12V ~ 15V
Output current: Max 1.8A
Operating Temperature: -40 ~ 85 C
Overcurrent shutdown: Min 3.4A
Observed Behavior
Pictures:
Input: DC 12V ~ 15V
Observed Behavior
- Mode Switch
- S = Parking Mode Off
- When parking mode conditions are met, the accessory and constant power will be turned off
- P = Parking Mode On
- When parking mode conditions are met, the accessory power will be turned off and the constant power will remain on
- Power Levels / Triggering Events
- Not Plugged Into OBD-II Data Link Connector => Plugged In
- Accessory power and constant power are turned on
- Parking Mode Conditions
- Enter Parking Mode
- Vehicle is stationary for 5 minutes & vehicle system voltage (pin 16) is below 13.5 volts
- Accessory power is turned off
- Vehicle system voltage is 13.5 volts or higher
- If the vehicle system voltage remains at or above 13.5 volts, the accessory power will remain on no matter how long the vehicle is stationary
- Exit Parking Mode
- Vehicle begins moving & vehicle system voltage is between 11.2 volts and 13.49 volts
- Accessory power is turned on
- Vehicle remains stationary but the vehicle system voltage increases to a minimum of 13.5 volts
- Low Voltage Cutoff - While In Parking Mode
- ** Note **
- Since 12-volt power is being provided to the dash camera, the dash camera's internal low voltage cutoff feature can be used to shutdown the dash camera based on the user selected voltage level in the firmware settings of the dash camera.
- This section is simply documenting the IROAD OBD-II power cable's internal low voltage cutoff feature as mentioned in the product's quick start guide.
- Vehicle system voltage goes below 11.2 volts for at least 2 minutes
- Constant power is turned off
- Vehicle system voltage is below 11.2 volts but rises to at least 11.2 volts
- Constant power is turned on, but accessory power remains off until the vehicle moves or the vehicle system voltage reaches 13.5 volts.
- ** Note **
