spotnz
without looking, I strongly suspect that SSD is the best long term storage solution, in terms of both cost & capacity
I think in general cost is about the same as they both contain essentially the same memory chips.without looking, I strongly suspect that SSD is the best long term storage solution, in terms of both cost & capacity
It's not on the current spec sheet, although it was on an earlier one so maybe it is an OEM option?What about WiFi support? will be a great and useful addition.
I could try it in my freezer, ...but that is colder than my freezer!I'm curious if any of the testers have used this camera at lower temps like -10 degrees F to 20 F? I live in the northern US and it gets COLD here.
Do you not heat your vehicle when in use?
What problems do you expect?
That sounds like a good idea - you need to speak to Rayman Chan...I can't believe one of the testers is not in a state or country that gets as cold as it gets here....if not...send me one of the cameras and I will put it in my cold car outside and try it out
The product was made for the German market so I'm sure cold weather use is taken into account
It's not significantly different from the other 080x models, how did they fare in the cold weather?
That will be the range over which it is guaranteed to work, obviously after you remove the extra zero from the C value!0C – 400C (32°F to 1040F)
Just a question but why are there two micro SD-slots?
T | Mini 0806s GPS modul dead | Mini 0806 | 1 | |
S | Mini 0806 Battery and Firmware | Mini 0806 | 0 | |
M | there is a listing of the error codes for mini series or for mini 0806 | Mini 0806 | 2 | |
Replacement mini 0806? | Mini 0806 | 3 | ||
J | Mini 0806 USB connection? | Mini 0806 | 4 |
