thephatmaster
- May 14, 2017
- United Kingdom
Hi all,
I have a long-serving Mobius that's not booting reliably. It's just hanging at a blue LED. Or, sometimes, a brief flash of the blue and three flashes of the red - then nothing - no leds.
The Mobius has seen a lot of use, and taken a lot of whacks. It's been used as a ski camera, dashcam, cycling helmet cam, second camera for youtube videos - you name it.
Not sure of the hardware revision but it has 2015 written on the board.
Hi all,
I have a long-serving Mobius that's seen a lot of use - used as a ski camera, dashcam, cycling helmet cam, second camera for youtube videos - you name it.
My dad wanted to borrow it for gliding and the battery was getting tired so I replaced the battery like for like (800-ish mAh one), and put a 128GB card in (Amazon Basics).
I got it back (he hadn't even been using it) and now it won't boot up reliably. Most of the time it just freezes at a blue LED and seems unresponsive. Nothing from the red LED. To power it back off I have to hold "power" down.
Or it does the brief flash of the blue, followed by three of the red, then turns off.
Things I've tried so far:
I got it back (he hadn't even been using it) and now it won't boot up reliably. most of the time it just freezes at a blue LED and seems unresponsive. Nothing from the red LED. To power it back off I have to hold "power" down.
Hi all,
- Charging until the green LED went away;
- Booting with and without the SD inserted;
- Resetting it with a pin;
- This did get it to boot once into mode 1 - I shot a quick video (LED flashed orange and it wrote a file) but it froze again after a few seconds.
- Trying the SD card in my PC (the brief video I made was fine);
- Trying to view footage on my PC with the camera connected over USB (also fine);
- Opening it up:
- blowing on everything in the usual way;
- checking the board for obviously blown / damaged components - nothing obvious;
- removing and re-seating the battery;
- removing and re-seating both ends of the lens connector
- Opening it up:
