wibbly
Has anyone measured or found the power consumption (in mA) of the A129 Duo in its different parking modes?
in parking mode dash cam use 4W for every hour? how do u calculate this?Dashcam consumes around 350mA at 12V (approx 4.2W) in driving mode with WiFi and display off, rear camera connected. And 300mA at 12V (approx 4W) in parking mode with WiFi and display off, rear camera connected. For time lapse and low bitrate in parking mode consumption is still the same.
It uses 4Wh per hour, so if you have a 94Wh dashcam battery, and the battery is full, then it will run for 94/4 hours = 23.5 hours.in parking mode dash cam use 4W for every hour? how do u calculate this?
Lead Acid batteries vary so much depending on their age and their temperature, and the car they are installed in.0.35A x 12V = 4.2W. Watts is not "per hour". Probably a better measure for what it would take out of your car battery (if that's what you're using) is 0.35A consumed for an hour = 0.35Ah. Your car battery which has a notional total Ah rating. So if it's a 80Ah battery it would lose an extra 100 x 0.35 / 80 = 0.44% percent of it's capacity every hour. So 10.5% in 24hrs. Bear in mind it won't be starting at 100% capacity and shouldn't be discharged below 50% really. My car maintains it's battery at about 80% as 'fully charged' to make it last longer. So I have around 30% of it capacity I consider "usable".
0.3A x 12V = 4W. Watts is not "per hour". Probably a better measure for what it would take out of your car battery (if that's what you're using) is 0.35A consumed for an hour = 0.35Ah. Your car battery which has a notional total Ah rating. So if it's a 80Ah battery it would lose an extra 100 x 0.3 / 80 = 0.38% percent of it's capacity every hour. So in theory 9.1% in 24hrs. Bear in mind it won't be starting at 100% capacity and shouldn't be discharged below 50% really. My car maintains it's battery at about 80% as 'fully charged' to make it last longer. So I have around 30% of it capacity I consider "usable".
Ohm's law is about resistance, doesn't really apply to a dashcam, since dashcams use constant power, independent of voltage or resistance.Nice to see a person who knows Ohm's law and knows how to treat his starter batteries.
I still say that your dashcam will use the same number of Watts, whatever your battery voltage and whatever the resistance in your cables, so neither of those formulas is of any use in calculating how long the dashcam will run from an eg 100Wh battery. The calculation you need is simply battery Wh / dashcam W, so 100/4 = 25 hours, and I don't see what that has to do with Ohm's law.Well !!!
There must be something you have completely misunderstood as the formula for Watt (P=U*I) is a derivation of Ohm's law (U=R*I).
I would like you to give a few calculated examples of your perception of the effect on dash cams when Ohm's law does not apply there.
If you have a battery that is specified in Ah instead of Wh then you could possibly use Ohm's law in the conversion, but it is much easier to simply use: battery Ah * nominal battery V, so from above 80 * 12 = 960 Wh. Realistically you will never get anywhere near 960 Wh out of a car battery though, even Wibbly's 30% is optimistic! Calculation does work for lithium batteries.
If you take your old Danish incandescent 60 Watt 230V bulb and plug it into a USA 120V socket, it will only use about 30W. This is different to a dashcam, which will always use the same amount of power, whatever the voltage, and since the HWK uses a switching regulator, resistance doesn't come into it.Yes, a 60 Watt light bulb should emit approximately the same light regardless of whether it is made for 230 Volt or 12 Volt.
Agreed. IMHO the only sustainable parking modes are those that consume less than, say, 10mA or so. And in most cases where such a mode is available, startup times mean the camera misses the event it's there to capture :-(Dear friends, practice shows that a lead-acid battery with a capacity of 80 Ah, discharging from 100% (12.7 V) to full discharge (12 V), produces approximately 35-37 Ah. But such a discharge is destructive for the battery. It is not recommended to discharge it below 12.5 V and leave it in this condition. The recorder wire can limit the minimum voltage to 12.4 V, so on a battery with a capacity of 80 Ah, with a current consumed by the recorder of 300 mA, the voltage drop from 12.7 V to 12.4 V takes about 4-5 hours. Then the recorder turns off. These are not just my observations. With current consumption of 300 mA in parking mode, this mode is not very functional.
S | Parking Mode Hardwired + Power Bank | A129 / 129 Duo | 0 | |
H | What is the Power Draw from a Hardwired A129 Duo in Parking Mode? | A129 / 129 Duo | 20 | |
J | A129 Duo parking mode power option? | A129 / 129 Duo | 9 | |
Power efficient parking mode | A129 / 129 Duo | 3 | ||
S | A129 parking mode not working by powerbank ! | A129 / 129 Duo | 37 |
