Pianoman144
- Sep 7, 2016
- Germany
Hey Community ,
after i mounted a CPL-filter on my Dome D201, i want to share a quick tutorial how to do this because there are only filters for the D202 or D205.
1. What i have bought:
- A 37mm to 49mm step up ring (filteradapter) It has to be a one with inner diameter of 37mm!
My is from LUMOS-66 http://www.ebay.de/itm/172344730172?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
- A 49mm Slim CPL-filter.
Just search at ebay or google. I have bought this from ebay http://www.ebay.de/itm/110815754734?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Just make sure you buy a high quality and real glass filter.
2. Prepare the Dome D201
First use a little screwdriver to remove the chrome ring. Just push it up. There are 5 little plastic legs on the ring to hold the chrome ring. They will brake if u push the ring up.
After u removed the chrome ring it looks like this:
Now you are ready to mount the adapter ring on the lens.
3. Mount the CPL-filter on
The adapter ring with inner diameter of 37mm fits perfectly over the lens.
Just push it over and u will see that it will sit solid. If u worry about it, you could use double-sided tap to fix the adapter ring.
Now you can screw on the 49mm CPL-filter.
There you have your CPL-filter mounted on successfully!
Here is a short video showing me how strong the adapter ring fits on the lens without taping it.
Thank you very much for reading this tutorial
