Vinz Clortho
- Feb 14, 2016
- Thinkware X500 with TWA-X500F750R Rear camera
I have a Ford Transit connect cargo van with no rear windows. I also have a Thinkware X500 2 channel dash cam with a rear camera (not connected because no rear windows). I have it Hardwired, although I could not find a switched (ACC) circuit in the fuse panel so I ended up installing a switch in the wire and then wiring both to constant power. When I park I have to turn off the switch so the camera senses that it lost ACC power and goes to parking mode.
Anyway, my question is this.. If I buy the new SGRCWPC camera from Street Guardian and Pier 28 which is a waterproof external camera with the same basic specs as my existing rear camera and connects to the primary camera/DVR using a micro USB connector the same as my existing rear camera will it work? Is there a standard spec for the micro USB connector so that the Power and video are on the same pins even though they are two different cameras from two different manufacturers from two different countries?
I really need a rearview camera, and will need to go with something external and waterproof because of no rear windows, but it would be best if I can also record it and view it with my existing X500.
Thanks for any Help or thoughts on this subject.
