There are a range of external dashcam power packs, but if you think a battery in the camera itself then no, some do have a small 400 mah battery for emergency power where others use capacitors to do the same, but these small internal batteries are not meant for powering the camera for long, just to do a clean shut down in case of a catastrophic event.
you will still need to draw a power wire to the front camera, and a wire to power and get video from a possible rear camera, if the rear camera had wifi to talk to the front you would still have to power it with a wire.
External batteries or your cars lead acid battery, well if you use them to power when parked, then you of course also need to drive to replenish the battery, a car lead acid battery charge fast ( many Amps ) the dedicated power packs also charge OK but i think the fastest i have seen is around 15 A,,,,,, which are a lot slower than your car charge your lead acid battery.
Downside is lead acid batteries you can not discharge deep without destroying them fast, the lowest recommended cut off voltage for lead acid are 12.2 volts.
Whatever you cant have your cameras recording for 23.5 hours a day and only drive for 30 minutes, that would not be enough to get your batteries up to 100 % and so you will soon "spin out " and have no power for the camera ( dedicated dashcam power pack ) or power for car and dashcam ( you can start a car with lower voltages on a nice summer day, on a frosty winter day you want / need a not more cold cranking power,,,, all you can get )
Many cameras today have wifi, but wifi to do settings on your phone and maybe DL a single file now and then, the cameras have very small antennas and weak radios so a transmitter inside your metal car will not reach very far,,,,, we are talking a few meters here at best.
Using wifi to say backup your daily recordings when you get in range of your home wifi, that is a hornet nest i will not put my hands inside, but there are a little official with some brands as i recall and some DIY mods for other brands.
Whatever NOT something i would bet on,,,,,, also you should not save all your footage, at least not if you are just a guy driving your car, for normal people dashcams generally generate garbage footage you do not need as nothing have happened worth sharing.
