Brandon53150
- Dec 13, 2016
I purchased an A119 a couple of days ago. When I received it, the GPS didn't work and it would not power on using the USB port in the GPS mount. It would power up and operate normally when using the camera's side USB port. As I've been a lurker here for awhile, I did some searching and someone mentioned a common problem with the ribbon cable not being properly seated. I opened up the camera and sure enough, the ribbon cable was not connected to the COM2 board that the GPS mount connects to. I reconnected it and tested, but when the ribbon cable is connected, the unit will not power on at all no matter which port I plug power in to.
Is it possible that there is a short somewhere and, if so, what is the technical name for these parts that I can talk to VIOFO about? I have tried to submit a help ticket and explained it much the same way I did here, but they think I'm talking about the GPS module being defective. I can't tell if the GPS module is defective until I can get power and connection to the pins first.
Many thanks!!
Many thanks!!
