If they have gotten rid of the CHK errors with item 3 that would be great news!※ updates
1. Set a regular time power 3, 6, 9 additional hours set ( Standard only )
2. Wifi Channel Settings Viewer also added to the Android app - WIFI channel automatically or 1-13 CH
Add that user to set
3. System Stabilization
That's great news - thanks for the heads up - I'll get it installed this afternoon and see how it's looking for me here too
It shows the following changes:
You're using newer than FI11?
I really hope so as Fi11 has got even bigger issues than the older versions - audio is totally screwed now!
Picture wise it looks good but something is properly screwed with audio on mine. I'll try a full reset tomorrow morning and see if that helps with this new problem.
The milage counter is still wrong on Fi11 - I did 67.2 miles tonight according to TomTom and the Lukas has registered 83.4 on the video.
No sign of the CHK errors yet. The milage issue is cosmetic so not a show stopper and if they've fixed the CHK errors that's great, but if they can fix the CHK errors and the audio then that would be much better - hopefully they're not mutually exclusive :/
Fresh format from lukas pc software. CHK error occurs every ten seconds with rear camera, ran without rear camera for 4 minutes without error.
lukas sd card write test 16mb/s san disk 32 mb/s
Lukas have replied to say that they have replaced the version of Fi11 that was initially uploaded and that the new one should now work correctly.
http://www.lukashd.com/gnuboard4/bbs/board.php?bo_table=eng_firmware&wr_id=127
I'll give it a go from here too.
Also Fi11 has been released for other Lukas models including the 9100, 9300, 9350, 9500, 9700 and 9750.
C | Need address to order (Lukas) memory card | LK-7950 | 1 | |
Lukas 7950 on startup keeps repeating some Korean Goobly Goop | LK-7950 | 9 | ||
I | Lukas LK7950 Hardwiring | LK-7950 | 5 | |
L | Lukas LK7950 Fi13 Firmware | LK-7950 | 10 | |
The Lukas LK7950-WD has landed - dual channel TI / Sony IMX322 dashcam with Wi-Fi - Ongoing review | LK-7950 | 134 |
