Will let you know when it fills up if there are any issues (takes me a few days).
Try a different (earlier) firmware. Some users reported those problems with this version.I am having issues.
When my SD Card is full camera won't auto boot and start recording. Only red light turns on. Have to manually turn on and start recording.
After a format it automaticly turns on and starts recording.
I am using a Lexar 8GB Class 6 SD Card. 1 minute loop.
Latest firmware with KPH and MPH, default German changed to English.
Any suggestions?
Thats the downside of having a higher bitrateI'm happy to report no overwrite issues when full; It's working without issue. I will note that recording at the higher bit-rate means my 32G card stores only about 3 hours of video (176 minutes on last tally). Previous fw recorded closer to the 240 minute range.
Hi @idemirci I have made the firmware for you, you can download it here: http://www.speedyshare.com/fK6TN/firmware-NO1-SPIF-TB15.bin
- Select 'slow download'
- Copy the file to your SD card, turn off the device, turn it back on and it should ask you if you want to update!
- Remember if it won't ask to update, try changing the filename to: firmware-NO1-SPI-TB15
Enjoy!
I don't think a silent FCWS alarm would be much use!
I have worked out how to play/modify the pcm files, I think maybe those are the only ones used.
Install Audacity - http://audacity.sourceforge.net/
Go to File > Import > Raw Data…
Choose the PCM file you want to open.
Select Encoding: Signed 16 bit PCM
Select Byte Order: No endianess
Select 1 channel (mono)
Select Start Offset: 0
Select Sample Rate: 12000 Hz (for the *_12k.pcm files)
Select amount to import: 100%
You can now play it or save it as a .wav file.
Haven't tried exporting a modified one yet but it looks straight forward.
Mini0801 Faulty LCD? | Mini 0801 | 0 | ||
Fake Mini0801 internal views (red menus) | Mini 0801 | 39 | ||
P | TS Version mini0801 Firmware Update from20130617 | Mini 0801 | 1 | |
Z | Mini0801 by Jado | Mini 0801 | 14 | |
Mini0801: First German reseller | Mini 0801 | 10 |
