Parthymon
So I just installed the A229 duo and after a little messing around and reading, I got it to go into wifi station mode just fine and get on my home network. I was able to navigate to the camera's homepage where you can download the files, etc and I was also able to view the livestream with VLC. Here is the kicker though and I'm not sure if it is something I need to set or if it is just not possible. The ability to download the files regularly from the convenience of my pc over the network was one of the reasons I liked these cameras in the first place. I installed the a229 hardwired with the ACC and Battery fuse splitters. What I've found is that it seems like the wifi station mode only works with the unit is "on" with the car being on. Turning off the car, the unit goes into parking mode just fine and everything, but turns off the wifi. And upon turning the car back on, putting it back into wifi station mode is a manual process again.
Am I missing something here? What exactly is the point of the wifi station mode if I have to have my car running in order to use it? I kinda thought the point was to make downloading the files a less manual affair but clearly, it's easier to just take the sd card in and use the reader on my computer than you leave my car running while I download them over the wifi. Is there a setting or something I'm missing here to keep it in wifi station mode while parking mode is active and the car is off? Thanks!
