Have you open Safego main unit and looked inside ? Does it have an EMI coating on the inner shell ?Panorama X2
Yes, happy. An excellent device for $ 200
Its easy to open. 4 srews on top which holds bracket mount and 2 scews on side.I haven't disassembly scheme
You brought up the Yamaha city car bub so I fail to see where you're going with that.....people in glass houses and all that jazz.Thank you for your information.
This is a topic about the engines and cars of the brand Yamaha?
they also helped develop a few hot motors for toyota aside from the altezza. in the 80s, they worked on the 3s-ge (naturally aspirated) and 3s-gte (turbo) enignes used in the mr2, celica all-trac and a few other vehicles. back when my first car, an 88 camry, was still new(ish) i always wanted to swap in the mr2 turbo motor, since it was a direct bolt-in. sleeper.Yamaha also built the v6 engines in the first Taurus SHO models....
"swiss cheese edition" (https://dashcamtalk.com/forum/threads/mini-0803-heat-issue.5913/page-2#post-79737) + radiator + SanDisk Extreme 64Gb = no problem
Can you please also check a main unit inner coating ?
Do not needbto check, it's on my controlCan you please also check a main unit inner coating ?
